Screen is black but I can feel it vibrate
Hi my mate 20 lite was doing finr i charged it and try’d to open it up the vibrate from the starting wroks and i feel it vibrate if someone calls me
좋은 질문입니까?
좋은 질문입니까?
Hello Zero,
if you opened the phone, there‘s the possibility that the display connector isn’t plugged in properly or you damaged the display by accident during the opening procedure. Try to open it another time and control if the connector is plugged in properly. You can check if the display is working before reapplying the back cover with anew adhesive. In case I didn‘t get you right, and you did not open the phone, it is likely that your display is broken because of water damage or similar. In this case, you need to replace the screen. The vibration motor is still working because it isn’t connected to the display but to the daughterboard.
이 답변이 도움이 되었나요?
지난 24시간: 1
지난 7일: 2
지난 30일: 6
전체 시간: 1,691
