주요 콘텐츠로 건너뛰기
3MB 공유 L3 캐시 1.8GHz 듀얼-코어 Intel Core i5 (Turbo Boost 최대 2.8GHz)
371 질문 전체 보기
What is this Vertical bar of Inverted Colours on my Screen?
I was cleaning my Macbook Air at the weekend and think I might have damaged the screen. A vertical bar of inverted colours appeared on the left-hand side (the right was fine initially) but then both sides of the screen displayed as shown in the image.
After about an hour of doing nothing, the bar on the left-hand side returned to normal but the right-hand side bar has been there since.
I’ve tried:
  • Pressing around the screen (does nothing)
  • Cleaning it again (gently and with no cleaning fluid)
  • Connecting it to an external monitor (output is fine which suggests the GPU is fine)
Any ideas what has happened? It’s a 6-year-old machine but I’ve never had any issues with it until the weekend.
Does the screen need to be replaced?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 2개
선택된 답변
I hope no water/cleaning detergent dripped into the frame as under there on the bottom side you got the full array of screen panel components and if that’s the case, screen might be fried. Try reseating the connector after unplugging the battery just not to let that untried.
해당 답변은 도움이 되었습니까?
점수 2
댓글 1개:
Afraid so...just strange that it broke on one side and then reversed later on.
댓글 달기
I suspect you used a spray cleaner on your screen and the liquid dripped under the bezel wetting the LVDS connector. Now you have a resistive short as the cleaner has dried but left a film of corrosion across the connection.
At this point you’ll need to try to clean the connections. To even get to the connector you’ll need to take the display fully off following this guide MacBook Air 13" Mid 2012 Display Assembly Replacement with the display off slide the clutch cover off to expose the bottom of the display. Locate the LVDS cable connector carefully remove the cable so you can clean the connector.
If you can’t clean it then you’ll need a new screen MacBook Air 13" (Mid 2012) Display Assembly
MacBook Air 13" (Mid 2012) Display Assembly 이미지
상품
$164.99
해당 답변은 도움이 되었습니까?
점수 2
댓글 1개:
OK, thanks for your help. What do you suggest attempting to clean it with?
댓글 달기
귀하의 답변을 추가하세요
John Peden 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 7
전체 시간: 1,411
