주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2017년 11월 4일 출시. A1865, A1901. GSM 또는 CDMA / 64 또는 256 GB / 은색 또는 스페이스 그레이. ("iPhone 10"으로 발음합니다.)
iPhone X memory upgrade?
Hi, so I’m going to replace the logic board on an IC locked phone and was curious if I could put a 256gb one inside. It’s currently a 64gb
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 1개
Anyone else have any ideas? I wanna make sure
댓글 달기
답변 3개
선택된 해법
I agree with Tom. It is, technically possible, to upgrade the memory on an iPhone X. Whether or not it is cost effective really depends on where you are in the world. The actual memory chip is quite expensive and it requires that you have access to a special programmer, such as this one. Additionally, there is quite a bit of skill required (and lots of specialized tools) to do this upgrade successfully. If it goes sideways, you will kill the logic board. Replacing the logic board is easier but certainly not inexpensive either.
So if you are in Asia, then you can probably have this done affordably. If you are in the US, then the cost will be significant.
이 답변이 도움이 되었나요?
점수 4
댓글 3개:
Is replacing the logic board as simple as just swapping them out? And also out of curiosity would I be able to buy a 64gb logic board then if I wanted to later on just buy a memory chip to upgrade the memory on the logic board? You guys are being very helpful I appreciate it!
And also what problems would you meet if you bought a 256gb board I’m assuming with the chip already on it and just put it into the iPhone, technically would that be the same thing as flashing the chip to match the serial number of the previous board?
You should re-read my answer. I detail that upgrading the memory is both expensive and difficult. This isn't a microSD card ;>). The logic board is the phone...if you swap boards, you essentially have a new phone.
댓글 달기
It is possible after you reprogram several serial numbers on the flash memory chip.
이 답변이 도움이 되었나요?
점수 2
댓글 6개:
So that’s the only way? The memory chip isn’t apart of the mother board?
If I’m replacing a 64gb with a 64gb it won’t require any flashing, correct?
You need to flash the chip every time, the chip is personalized to each board.
That would make sense but why aren’t any guides telling you, you need to flash the chip before putting in a new board?
If you put the entire logic board and home button then it isnt needed to program the chip. you can swap it easy no troubles.
댓글 1개 더보기
댓글 달기
How To Upgrade iPhone X 64GB Storage To 256GB
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Connor 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 14
전체 시간: 3,592
