주요 콘텐츠로 건너뛰기
Repair manuals for laptops manufactured by Microsoft.
336 질문 전체 보기
Can I replace the internal hard drive?
hello,
my internal hard drive seems to be corrupted and the Bitlocker is activated with no password in hand.
so its seems that the solution to fix the problem would be replacing the hard drive. i cant get anywhere pass the troubleshoot when starting up the device.
anyguides on how to proceed to open the device. the process would be just opening the device, taking out the old and placing the new? and how to choose when buy the new hard drive, perphaps improving it since i would be opening it anyways.
really appriciate your help in advance.
Eduar Ryser
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 2개
Hi @eduar ,
What is the name and model number of the laptop?
microsoft surface book. 8 Gb ram, 256 Gb, Intel 5.
댓글 달기
답변 2개
선택된 답변
Bitlocker should not matter. Try booting into windows install USB drive and completely erase the drive.
해당 답변은 도움이 되었습니까?
점수 2
댓글 3개:
the bitlocker wont even allow me to get into that. i cant access any disk because it says its blocked.
You don't need to get past the bitlocker, just boot to Surface UEFI, choose boot from external USB and start from Windows installer drive. When you install Windows, delete every partition on Disk 0.
Also recovery key for BitLocker is usually under your Microsoft Account, or Azure AD account if it is AAD joined.
댓글 달기
Microsoft Surface Book Teardown
Not sure about the upgrade part. Maybe someone else can help with that.
Good luck
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
귀하의 답변을 추가하세요
eduar ryser 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 3
전체 시간: 107
