주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Xiaomi Mi A2(전 세계적으로 Mi 6X로도 알려짐)는 2018년 7월 다양한 내장 메모리 구성으로 출시되었습니다. 이 기기는 2년간 업데이트를 보장하는 Android One 프로그램의 일부입니다.
Backlight only works during startup
I recently changed the screen on a Xiaomi Mi A2 Lite. When I start the phone up, the Android One logo displays with full brightness and colour without any issues.
The problem is that once the phone turns on there is no backlight. You can still see the display if you are in a dark room and everything seems to show correctly. I have tried updating and factory resetting but still having the same problem.
Any advice would be much appreciated.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 3개:
Did you ever find an answer to this issue? My phone developed the same problem yesterday.
I have the same problem with a replacement screen. Did you find any solution?
Have you found what was causing this?
I’ve the same issue, replaced the lcd on a xiaomi mi a1 and the backlight is present at the logo startup but completely black after that.
On a dark room I can barely see the screen and all it’s working, but adaptive light button is missing, seems like the bootloader is able to use the backlight but not android itself
댓글 달기
답변 1개
I’d try to disable the “adaptive brightness” feature under settings->display, but I highly doubt that this can solve an issue like this.
On the software side there should be restrictions in place to how dim the screen can get and I’ve never even heard of the software having the permission to turn the backlight off.
The only suggestion then would be to replace the screen, but since the backlight is working upon boot…
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Ryan Storey 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 2
지난 7일: 4
지난 30일: 16
전체 시간: 1,348
