iPhone SE display has problem, motherboard not shorted
Hi guys, I have an iPhone SE here. The phone is not water damaged, hasn’t been dropped or anything. The phone has a strange problem. The phone can work perfectly for about 10-20 minutes, then suddenly vertically lines running across the screen appeared (see the attached photo). Then the phone went to boot loop. I successfully restored the phone to original factory settings, didn’t get any error. The phone would work for about 10-20 minutes, then same problem happened.
I connected the phone to power supply. It turned on fine, could boot into main screen, worked flawlessly, but I need to increase the power to about 4.9V. Normally a phone can be booted with 3.9-4V. But with this SE, if I set the power supply to 4V, the phone wouldn’t boot into main screen, it stayed in boot loop.
I didn’t see any short on motherboard, the board is clean. I don’t know where to start. Could it be the PMIC faulty?
좋은 질문 입니까?
