주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
LG 37LF65 LCD TV는 2007년에 출시되었으며 32인치, 37인치, 42인치 크기로 제공됩니다.
Color off in vertical section
( right model number is 37LK450UB )
In the far left vertical section of my screen, about 4 inches wide top to bottom, a certain shade of grey has suddenly become mustard yellow. Any idea?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 1개
Don't know if it makes a difference, but the TV is only connected to a PC via a HDMI cable
의 공유
댓글 달기
답변 1개
가장 유용한 답변
If the LCD screen isn’t damaged and my guess is not if clearly a vertical section issue that is symmetrical.
I would first check that all the ribbon cables are clean (unplug and use some 91 at least% IPA), you can blow out the connector also with an aerosol cleaner like Ultra Duster Clean or better and then make sure they’re re-seated correctly. This is regarding all the ribbon cables going to the T-Con board and out from.
Then do the same for the section of the LCD beneath the section that isn’t displaying correctly.
Usually, from what I’ve seen sometimes the ribbon cables that connect to the LCD Screen itself can become dislodged, corrode or something happens to the connection and in some cases pressure is required to be placed on the cable so seated in the connector. You can even press your finger on the cable to see if helps once you’ve cleaned that section of the LCD ribbon cables and connector.
This is an example of what I am referring to in a Sharp TV example if not one of the boards connections:
https://www.youtube.com/watch?v=purk_Syi...
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
Bob Harris 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 7
지난 30일: 24
전체 시간: 409
