주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Windows XP 기반의 Intel Celeron 프로세서를 탑재한 휴대용 노트북 컴퓨터입니다. 모델 번호: MS2109
I want to make a server
I have 4 computer in the house and i want all of them to be connected to one pc as a server and control all of them with 1 computer…. what must i have and do?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 4개:
Hi @naunyango
What do you want to control and what do you want to do with?
File Server ?????
yes file server.
What is your OS? Windows 10? If so, it's easy.
Window 7 ,,,
댓글 달기
답변 2개
I would set mine up as a Linux server using Samba because its free. Instructions here. You could also set up Apache and make your files available from anywhere.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
Jonathan —
Choose the computer you wish to use as a “file server.” Then, select the drive that will hold the files you wish to access. “Share” that drive. Then, go to each of the other computers and “Map” that drive on each of them.
Instructions here: https://www.dummies.com/computers/operat...
I am doing this with a six computer network using Windows 10. Works great. Let me know if any questions.
Good luck,
Russ
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
How to creat network password or which password do i need to use?
댓글 달기
답변을 추가하세요
Jonathan 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 2
지난 7일: 7
지난 30일: 33
전체 시간: 528
