주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
XP-410은 최신 무선 표준과 Wi-Fi Direct1을 지원합니다. 또한 Apple® AirPrint™ 및 Google Cloud Print™를 지원합니다. 내장 메모리 카드 슬롯, 2.5인치 LCD, 편리한 터치 패널 덕분에 PC 없이도 테두리 없는 맞춤형 사진을 다양한 레이아웃으로 인쇄할 수 있습니다.
My printer is will not print.
My Epson XP-410 printer will not print. Says it must be connected to the WiFi which it is. I have installed a new driver and updated the firmware. When doc is put in queue is says error. This printer is the default. What do I do next?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 3
댓글 1개:
Add new cartridge and still says it needs a new one
댓글 달기
답변 2개
Make sure both printer and computer are on the same network, ( wireless). if they are add the printer to the computer and it should work. if not visit the printers’s website for install support. https://epson.com/Support/Printers/All-I...
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
you should also check the printer IP and that of the PC driver property box... they must be the same... most of the time this error occurs when you are connected through LAN or Wireless... i will suggest you try printing through USB connection
댓글 달기
Are you using 3rd party ink? Epson is starting to pull a Lexmark with 3rd party ink carts and blocking them in firmware. This is happening on the small black cart printers and the traditional sized black cart ones.
PRAY you can get into recovery mode and downgrade the firmware to a revision that’s 2-3 versions old if you can find it, as Epson pulls old firmware to screw people into buying their ink. NEVER UPDATE EPSON FIRMWARE ON BLACK CART MODELS. Stick to a 3rd party safe firmware and DO NOT do it again. Hopefully you can use these instructions to downgrade the firmware.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Katy Waters 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 10
전체 시간: 3,189
