주요 콘텐츠로 건너뛰기
모델 A1311 / Mid 2011 / 2.5 & 2.7 GHz Core i5 또는 2.8 GHz Core i7 프로세서
432 질문 전체 보기
My fan does not run
I installed a new ssd because my hdd crashed. The fan worked before i installed it but now its getting really hot and my fan wont turn on. Did i install it wrong? I bought the upgrade from here and i followed all the step. Help
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 3개
선택된 답변
i figured it out. I installed a 3rd party fan control. I had to manually set the temperatures so the three fans could spin up. It was weird because it was set to auto and it would not do a thing.
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
Another good reason not to use software and use the in-line sensor.
댓글 달기
The thermal sensor should be responsible for this issue, you need to find a way to reduce the RPM of the internal fan down to the usual range. You may solve the problem with the help of reliable third-part software.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
Did you install the in-line thermal sensor this system requires? OWC In-line Digital Thermal Sensor for iMac 2011 Hard Drive Upgrade. Its part of the SSD upgrade kit iMac Intel 21.5" and 27" (Mid 2011) SSD Upgrade Kit
iMac Intel 21.5" and 27" (Mid 2011) SSD Upgrade Kit 이미지
상품
$100.99
해당 답변은 도움이 되었습니까?
점수 0
댓글 6개:
Yes, I bought the 1tb upgrade from ifixit and installed the In-line Thermal Sensor. I also try using a 3rd party fan control program and it does not seem to work.
Lets try running the onboard diagnostics to see if an error pops. Restart your system and press the D key.
Ok so i just booted it up and the fans are running really fast now, and the third party app says that there is no fans detected
And what did diagnostics tell you?
It says "No trouble found". I hear a fan turn on in the diagnostics. Currently the temperature is at 111 degrees Fahrenheit and the fans are not spinning at all,
댓글 1개 더보기
댓글 달기
귀하의 답변을 추가하세요
NamelessChat 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 3
전체 시간: 137
