주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
PowerMac G5는 Apple Corporation에서 2003년에 처음 제조한 데스크톱 컴퓨터입니다. 이 안내서는 2004년 Apple PowerMac G5 모델 번호 A1047 EMC 2061의 수리 과정을 검토합니다. 2006년에 먼저 개발자에게 그 후 소비자에게 Intel 스위치의 일환으로 판매가 중단되었습니다.
How do I manually update a old Mac?
I have received an old Mac Pro G5 running Mac OS X Leopard, and have tried updating it to its newest possible form. When I downloaded Mac OS X High Sierra and even Snow Leopard, it says “Can not update” when I try to open the update file (Through USB).
By the way, I was connected to the internet by ethernet.
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 1개
댓글 달기
답변 4개
선택된 해법
Your Power Mac G5 uses a PowerPC 970MP (G5) CPU which is based on the RISC architecture. The Intel CPUs (Core2Duo, i3. i5 & i7) are CISC based architecture. The OS’s are very different! Your system can only support the older Mac OS-X. The early OS-X OS’s where in fact dual binary! So the RISC code would be loaded on your system and if you had an Intel system the CISC code would load in! It was very novel in its day.
Here’s an interesting nugget! The A chips used in the iPhone & iPad’s are RISC based! And iOS is a branch off of the RISC OS-X code stream.
So what to do here?
If your system is working tinker around with it. Just don’t get online with it as your system is not secure from all of the malware, trojans and viruses that are now floating out there in the wild.
If the system is not working or you want to get more out of it, then maybe you might strip the case down and install an Intel based logic board - Hackintosh within a Power Mac! Retro Power Mac G5 Hackintosh & Power Mac G5 Conversion
이 답변이 도움이 되었나요?
점수 3
댓글 달기
가장 유용한 답변
The highest system your machine will take is 10.5.8. Retail Installation DVDs can be found on eBay. Do a search for “Mac Leopard OS X 10.5” https://www.ebay.com/itm/Apple-Mac-OS-X-...
Be sure to get the Full Version, not the update.
이 답변이 도움이 되었나요?
점수 4
댓글 달기
It’s because it does not support newer versions. You can check Apple’s website for list of OS’s supported devices.
이 답변이 도움이 되었나요?
점수 2
댓글 달기
You need to keep up to date your mac. Update it manually or automatically. In automatic process you need an software or tool. In manual way choose Apple menu > System Preferences, then click Software Update.
You can clixk on Apple menu button where the number of updates are available.
Tip: You can also click the Apple menu—the number of available updates.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
William Sherman 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 21
전체 시간: 6,860
