주요 콘텐츠로 건너뛰기
TI-84 Plus calculator support.
20 질문 전체 보기
My screen is hard to see when looking straight at it
If I am in a lit room I can’t read my screen when looking straight at it. I have to look at it from an angle. It looks like there is a dark circle covering the screen but it’s not there when the screen is off
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 2개
There could possibly be a problem with the LCD in the device, depending on use and time that you’ve used it, or possibly just the battery needs to be replaced which could very well be causing the problem.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
Adding onto what TheYootx Media Group said, another possible issue is the contrast was turned down too far. You can easily fix this by (make sure the calculator is turned on) repeatedly pressing [2nd] then the up arrow until you can see the display again. If this doesn’t work then it’s either a battery issue or a display issue. If there’s a display issue, then this article may help you repair it.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Mary Ringgenberg 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 5
지난 30일: 8
전체 시간: 548
