주요 콘텐츠로 건너뛰기
Vizio 42" LED TV released in September 2012.
45 질문 전체 보기
No audio output via RCA or Optical
For many years, I have ran RCA cables from back of this flat screen, to my Carver preamp’s video 1 input. Recently, the signal went bye-bye. I tested all the pre-amp’s RCA inputs and all work properly. Thinking there might be an issue with the RCA audio out’s of Vizio, I bought an optical cable and an optical to RCA converter This did not work, leading me to believe the issue lies with the audio outputs on the Vizio. Has anyone encountered this? If so, what is the solution?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 2개
What are the chances that if the RCA connections are burnt out of the optical will be to?
@Alex Couch
The actual connections both won't be burnt out.
As one is analogue output and the other is digital the most common factor to both would be the audio amp.
The DSP (digital signal processor) in the TV would send the audio signal derived from the input signal, to the audio amp where it would be sent to the RCA connections and the optical connection as most TVs only have the option to select internal or external audio output i.e. internal TV speakers or external audio amp or speaker and not then to either the RCA or the optical
댓글 달기
답변 1개
가장 유용한 답변
ion39  This error sounds like a bad audio amp and no surprises there since those are usual skimped on. It is located on the main board. Since Vizio is at best a mediocre company with mediocre support and there are no schematics etc. available, your best bet would be to try a new main board. of course try a reset by unplugging all inputs. Unplug the TV and hold the power button for 30-45sec. Then plug the TV back in and only one video source. See if that changes anything.
해당 답변은 도움이 되었습니까?
점수 2
댓글 2개:
Thanks for your reply! I get the reset objective, but re: "power button"...you must be referring to remote's power button, because the flatscreen doesn't have one, at least, that I can see.
yes that should work. definitely unplug it and leave it for a bit.
댓글 달기
귀하의 답변을 추가하세요
ion39 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 3
전체 시간: 1,057
