주요 콘텐츠로 건너뛰기
2014년 9월 19일에 출시된 이 4.7” 스크린 iPhone은 iPhone 6 Plus의 작은 버전입니다. 모델 번호 A1549, A1586 및 A1589로 식별됩니다.
4994 질문 전체 보기
Microphone issues on iPhone 6
iPhone was in water and sand few days ago and now microphones are not working. I tested all 3 microphones with Auphonic app and by recording video and all of them sounds like someone blowing air directly to microphone.
On bottom microphone my voice is barely heard.
On top front and top back microphone there is just strong wind and nothing heard even when i shout right at the microphone.
I tried cleaning microphones with tissue, cloth, toothpick and even a sticky gum but no difference.
I want to know how can i fix it. Any help is appreciated :)
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 답변
Assuming the water didn’t get into the phone core, the logic board, you may try replace both parts that seem to be damaged, or clogged by sand. Here you can find the guides that can help doing the job..relevant parts can be purchased on iFixit store too, you’ll find the links within the guides pages.
iPhone 6 전면 카메라 및 센서 케이블 교체
iPhone 6 이어피스 스피커 교체
iPhone 6 Lightning Connector Assembly Replacement
iPhone 6 Lightning Connector Assembly 이미지
안내서
난이도:
어려움
1 - 2 hours
iPhone 6 이어피스 스피커 이미지
안내서
난이도:
운영
30 minutes - 1 hour
iPhone 6 전면 카메라 및 센서 케이블 이미지
안내서
난이도:
운영
30 minutes - 1 hour
해당 답변은 도움이 되었습니까?
점수 2
댓글 2개:
Thank you for your answer! I don’t understand if i should replace earpiece speaker or front camera and sensor cable for front speaker. Also can you please add link for the back microphone replacement guide.
@numan99 Earpiece speaker gets and transmits signals through the camera/sensor/upper microphone flex cable. Given the problems the phone suffered I'd replace them all once you're doing the job, parts come quite cheap anyway. Rear upper microphone is on this other flex and relevant guide: iPhone 6 Power Button Cable Assembly Replacement
댓글 달기
귀하의 답변을 추가하세요
Numan 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 2
전체 시간: 56
