주요 콘텐츠로 건너뛰기
2014년 7월 28일에 출시된 Samsung Galaxy S5 mini는 8MP 후면 카메라, 720p 화면, 지문 스캐너 및 방수 기능이 있는 휴대 전화입니다. 이 휴대폰은 이전 모델 Galaxy S5에서 개선된 더 큰 화면, 늘어난 배터리 수명 및 카메라가 있습니다.
30 질문 전체 보기
Is it necessary to clean inside of my phone if it is fall into toilet?
My mobile phone was dropped in toilet for 12 hours. I dried my phone. But i think there is dust inside. But my phone is running very well. I want to know if the dust is harmful for the future?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 3개
선택된 답변
Hi @fixzahid ,
Water resistant doesn't necessarily mean waterproof.
The specs state that it can withstand water up to 1 metre for 30 minutes, which is a bit different to 12 hours submerged!
Whilst there are no problems for now that is not to say that they won't appear in the near future.
Just so that you are aware of this
Personally I would open it up to inspect it but I'm just cautious around electronics and water especially if the device is not new.
Are there any minute cracks in the case or flaws in the seal due to normal activity over time which may have compromised its’ water resistant integrity for example?
Here’s a link to the ifixit Samsung Galaxy S5 Mini guide, if you decide to do this
This link may also be of some help. Electronics Water Damage
Hopefully you also cleaned the outside of the phone appropriately given where it was found submerged and also how the phone is used ;-)
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
If your phone is running very well, then there is no need to fix anything for now. Samsung Galaxy S5 phones are water-resistant, so being submerged underwater probably didn’t cause significant damage.
해당 답변은 도움이 되었습니까?
점수 1
댓글 2개:
I feared about the dust,not the water. Will dust create any problem?
The mechanism in the phone that blocks the water will most likely block the dust as well.
댓글 달기
Yes its highly recommended you can run in to a lot of issues from it.
If I helped you please accept my answer답변 수락 방법
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Zahidul Nahid 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 10
전체 시간: 91
