주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2016년 9월 출시. 모델 번호 SM-G610로 식별
Why is my back button not working
What causes some keys not to work sometimes? I discovered the return/back button on my phone wont respond to touch often times. This is frustrating because it makes using an app that requires a return function difficult.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 6
댓글 3개
The same with my phone return button didn't work but when I tried to reset it works it features not the factory reset it work for several minutes only, then not working again, seems there's time elapse program to lock. I tried all options even the factory reset. The same happened working for several minutes only.
의
Can anybody suggest to solve this problem without going to any phone tech?
의
لقد سقط هاتفي مرات كثيرا علئ الارض
의
댓글 달기
답변 3개
가장 유용한 답변
Do you have a screen protector on the phone? If you do it could possibly just be a case of a bad cheap screen protector. If not it could be an actual issue with the buttons themselves. Or it could just be phone lag if they eventually do respond or if the phone freezes when you press them.
Hope this
이 답변이 도움이 되었나요?
점수 1
댓글 달기
I had this problam too, when i opened the phone there was a little water damage.
Are you sure it does not have any water damage…
이 답변이 도움이 되었나요?
점수 0
댓글 달기
My back button don't work at all
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Chinwe U-O 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 10
지난 30일: 34
전체 시간: 6,389
