주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2014년에 출시된 14인치 비즈니스 노트북. 시중에 나온 최초의 Haswell 기반 비즈니스 노트북 중 하나입니다.
Wiped SSD but Cannot Boot Anymore
Hi, I performed a successful ATA Secure Erase on my WD SSD (comes installed). This went fine. Upon going to turn computer back on after shutting it down, it only opens to a message:
Dell Security Manager
Hard Drive #######, the system internal HDD-0, is protected by a password authentication system. You cannot access data on this hard drive without the correct password. Please type in thehard drve password.
I put in the password and I get:
No bootable devices found
Press F1 key to retry boot.
Press F2 key for setup utility.
Press F5 key to run onboard dignostics.
I don't need to keep any data on the computer, I'm actually trying to get back in to do a factory reset, so if there's a way to do that without any of this that works also. The computer was running only on Ubuntu 18.04.
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 1개
선택된 해법
You need to reinstall the operating system. If you have another computer available to use, use that to create USB installation media for ubuntu and then you’ll be able to boot ubuntu off the SSD again.
You can download ubuntu here:
https://www.ubuntu.com/download
Use Rufus to burn the downloaded ubuntu ISO onto a flash drive:
https://rufus.ie/
이 답변이 도움이 되었나요?
점수 3
댓글 달기
답변을 추가하세요
Please help 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 6
전체 시간: 696
