LG Dishwasher lights “fritzing” when on, making erratic noises
Our LG dishwasher —Inverter Direct Drive-- recently started having its control panels lights flickering/fritzing when turned on, will make erratic beeping noises and will do this when the dishwasher is running. The dishwasher turns off mid cycle when this happens as well.
Update (03/30/2019)
Thanks for the response! I’ve taken off the front door and the control panel- I’ve don’t see what looks like a control board.
The front control panel doesn’t seem to have anything significant standing out to me as damage
좋은 질문 입니까?
댓글 22개
Hi,
What is the model number of the dishwasher?
Try switching off and totally disconnecting the power from the dishwasher for about 5 minutes and then reconnecting the power to check if has been reset back to normal operation.
jayeff 의
Hi- it’s a an LG LDF5545ST. I’ve already reset it several times by disconnecting it from the power.
Breata Jessen 의
Breata Jessen any chance you can post some close ups of the board in the second picture?
oldturkey03 의
I have tried to get LG to send me a replacement board even under warranty and they refused unless i paid a technician to do it . I have a masters in Mechanical engineering and they wouldnt do it. time to switch brands.
Sunny D 의
This happened to me. They cover the warranty of the part but not the tech. But won't send the part without a tech diagnosis. Stupid. I unscrewed the top panel and it was a loose wire. Problem solved. No new panel needed.
Megan Arner 의
댓글 17개 더보기
