주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2017년 9월 22일 출시. Model A1864, A1897. GSM 또는 CDMA, 64 또는 256 GB 저장 용량 옵션을 제공하며, 색상은 금색, 은색 및 스페이스 그레이가 있습니다.
Overheating and drainage fast.
Hello,
i have a question.
I run an repair shop and i repaired like dozens of phones.
i recently refurbished my own iphone 8 plus device to make it look new.. but now my phone is overheating entirly but at the power button it is even warmer.
the phone also lose 1% every minute when using it.
-housing replaced
  • original battery
  • Oem screen
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 3
댓글 1개
I got the same problem :(
Have you fixed it?
댓글 달기
답변 2개
가장 유용한 답변
Bad Tristar chip on the motherboard. Microsoldering required to repair it.
이 답변이 도움이 되었나요?
점수 1
댓글 2개:
Checked chip.
Its fine.
I notice when i am using the phone with on spotify and when using sound true top speaker the phone is getting hot.
Any solutions for that?
So,
This is the place where it heats up.
https://ibb.co/8Y5zDpG
On the front and at the power button it heats. The most i feels like 40c back site is little warm.
Rest of the phone is not as warm as the top
댓글 달기
Did you try a new battery? Also go into your settings go to battery and than battery health. If its below 82%, I recommend a new battery anyways.
이 답변이 도움이 되었나요?
점수 0
댓글 2개:
Changed housing,
Changed battery
Changed screen.
Everything works normal...
Just special apps like spotify , gaming its getting hotter as usual... and then the battery drains way faster.. like half of the time as before
I am running ios 12.2. i refurbished this one and i put my back up on this phone and had to update it. So i dont know if it was befoee the update aswell.. thats the problem.
Is it possible that it could be?
-faulty screen
-proximity sensor?
- copy power flex
- copy dock connector
Maybe just backup your phone and then do a DFU restore to see if that fixes it.
댓글 달기
답변을 추가하세요
glennjacobs 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 8
지난 30일: 19
전체 시간: 855
