주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
XV-21은 Neato Robotics에서 반려동물의 털과 비듬 제거를 위해 특별히 제작한 로봇 진공 청소기입니다.
LCD Display Not Working
My XV-21 display lights up but there is no display. I know you can replace it but does anyone now how?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 1개:
My lcd menu is empty. Light is flashing amber
의 공유
댓글 달기
답변 1개
Unfortunately I have had this same problem twice on my Neato XV (two years apart). Both times the problem was a broken LCD display card, replacing the card fixed the problem. I was able to buy a used Neato XV LCD display card on eBay for about $40. Amazon may have them too.
Follow the Neato XV-21 repair guide on ‘Motherboard Repair’ (thank you Nastassja Klipsch!!) Until you get the two halves of the robot apart. There are a ton of screws, so if I have to do this again I will take better care to write down where they all came from (I started to forget).
You don’t need to remove the Lidar unit, so stop at that point in the guide. The LCD display card is screwed into the top shell of the robot. Once you get the robot apart it is pretty easy to disconnect the cable connector and replace the display.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Doug Schommer 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 13
지난 30일: 28
전체 시간: 2,606
