주요 콘텐츠로 건너뛰기
2014년 9월 19일에 출시된 이 4.7” 스크린 iPhone은 iPhone 6 Plus의 작은 버전입니다. 모델 번호 A1549, A1586 및 A1589로 식별됩니다.
4994 질문 전체 보기
How to get iPhone to turn back on?
I left my iphone and put it to sleep, and then half an hour later, I went to turn it back on again and it didn’t respond. During that time, the phone was in my pocket doing absolutely nothing. I have tried all of the solutions that I found online including the force restart, etc. I have tried plugging it into my computer to see if it recognizes it, and it doesn’t. I have tried charging it and it still does not do anything.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 2개
Replace battery first and check that you can find the clue what you have to do.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
As Akash suggested, if you can remove the battery it will help. I would lift the screen and disconnect the battery, then plug the phone into a computer with iTunes installed. If the phone boots up with the battery disconnected, then the battery is likely the problem: follow this guide to replace it. If it doesn’t boot up, you should hopefully still get an error message of some description from iTunes. The error message should give you a better indication of what is wrong.
해당 답변은 도움이 되었습니까?
점수 0
댓글 2개:
An iPhone will not boot without a battery...
@refectio problem here is one cannot upvote the comment :P
댓글 달기
귀하의 답변을 추가하세요
Aryan Mistry 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 1
전체 시간: 47
