주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2018년 10월에 출시된 Samsung Galaxy A7 스마트폰의 2018년형 모델입니다.
Power reset or unknown upload mode
Hi, i have a problem with A750SN got stuck in bootloop. After i tried to enter download mode it shows me only “Power Reset or Unknown Upload Mode”, i have tried to connect it to Z3X and click on the “Reboot to Flash” the screen says OK but in the phone screen nothing is happening.
I will write the whole text that apears in the screen of device.
[RST_START = 0x1000000 ]
ECT : PARA002n
LPDDR4 manufacturer = Samsung
LPDDR4 Process ver = D18_B
LPDDR4 Size = 4G
LOT_ID = N0000
CHIP_ID = 0753b6b4924c
[TMU] 33, 29
asv_table_version : 2
big grp : 7
little grp : 7
g3d grp : 7
mif grp : 7
int grp : 7
fsys grp : 7
cp grp : 7
Please uncheck Auto Reset option of RDX!!
And do HARDRESET by using volume down + power key 7 secounds!!
CODE MATCHED (0)
Fatal exception in interrupt
PC is at hard_reset_hook_callback+0xdc/0x120
LR is at hard_reset_hook_callback+0xdc/0x120
I have tried the “ hardreset by using volume down + power key” but it still stuck in samsung logo.
If someone has any idea how to exit this and enter the download mode i would be very thenkfull.
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 1개
Upload mode Forced upload mode with key A10
의
댓글 달기
답변 5개
선택된 해법
The phone was water damaged and wouldn't recognize the USB cable.
이 답변이 도움이 되었나요?
점수 1
댓글 1개:
press power button + volum up and home button then yoU need to do factory reset data and go restart your phone and go to factory setting
and reset ur phone
의
댓글 달기
가장 유용한 답변
after I use Z3X and click on the “Reboot to Flash” , phone will get in download mode. Then i just put the file and click on flash
이 답변이 도움이 되었나요?
점수 2
댓글 달기
My phone have problem video player out repair my phone
이 답변이 도움이 되었나요?
점수 0
댓글 달기
Ok thats stupid ur phone has water damage mine has no water damage and says the same thing i just used odin on it so thats aload dog duddy im having the same problem if someone told me what the rdx was i could do it if u google rdx and android tells about cars with android fearures
이 답변이 도움이 되었나요?
점수 0
댓글 2개:
U must press power button with volum up and home button to get in android mode and do a hardware reset and clean all ur datas then go into ur settings of phone and do factory setting and reset your phone another time then it wouldn't come
의
@Buisan Kahbo I've try to press power button and volum up button only cause my phone doesn't have home button, but it's still doesn't work. What should I do?
의
댓글 달기
حالت آپلود اجباری حالت آپلود با کلید A10 The second SIM card does not work either
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Adrian Zymeri 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 15
지난 30일: 54
전체 시간: 16,134
