주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
A1708 / EMC 2978 — 2016년 10월에 출시된 이 엔트리급 MacBook Pro는 (OLED 터치 바 대신) 기존의 전통적인 기능 키를 유지하고 있습니다. 이 기능 키 버전은 인텔 코어 i5와 두 개의 썬더볼트 3 포트를 탑재하고 있습니다.
Access to files on SSD drive.
Hi,
Can you please call me I’m looking for an adapter that allows me to plug in a 2016/2017 non touch bar SSD drive to either a USB-A or USB-C port to read and test drives externally.
I would need about 10 of them.
Apple Blade SSD 5GA 34+22 Pins NVMe
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 3개
가장 유용한 답변
Sorry we don't call people - To expensive!
Sadly your model uses a very different SSD connector as you can see in this MacBook Pro 13" Function Keys Late 2016 분해도 jump down to Step 10.
So far no one has created one. Give OWC a call to see if they have anything thats the best I can offer you.
Your only option is to get access to another Fn MacBook Pro which you can swap out the SSD to gain access to your files.
이 답변이 도움이 되었나요?
점수 2
댓글 달기
Would installing my SSD into another working mackbook pro work exactly the same? meaning i would need the apple id and password from my SSD?
이 답변이 도움이 되었나요?
점수 0
댓글 달기
I don't have 10, I had 15 made and I think I have eight left, but I would be happy to send you my PCB file, and you can send it to PCB way like I did and they can make you as many as you want, I know the design works, I've been using it for years. I designed a custom PCB adapter several years ago and had PCB Way build several of them, specifically to recover data from 38+22-MacBook Pro SSDs. They're 38+22-pin to USB 3.2 Gen2x2, so quite fast, they get the job done.
Email me.
  • Jackson
  • PhixesPhones@gmail.com
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
My above comment has the caveat of, as long as you know your password, then you're fine you can use my adapter just like any SSD to USB adapter
의
댓글 달기
답변을 추가하세요
kirk 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 13
전체 시간: 2,355
