주요 콘텐츠로 건너뛰기
Released December 3, 1994 in Japan and September 9, 1995 in North America. Models SCPH-100x, SCPH-3000, SCPH-3500, SCPH-500x, SCPH-550x, SCPH-700x, SCPH-750x, and SCPH-900x.
Spindle is tight and it is not spinning
So my Playstation one model is SCPH-103. (DC:7.5V External DC Supply)
For my problem, I broke the spindle before so I have to replace a new spindle.
I just bought the spindle online and the spindle did not show for which model since I think all of it are same so I bought 3 from different seller. All of them are same after I received.
Now my problem is when I replaced it the spindle is tight and could not spin. Each of the spindle are same, it is tight when it put to the console.
What I watch from Youtube, after they replace the spindle then the spindle could easily be spin. Not like mine, after I put into it, it is tight and could not spin. I don,t understand..
So whats the problem actually?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 1개
Did you put the spindle on tight enough? Sometimes a spindle fails because it is rubbing against the housing. This could be because the spindle just needs to be pushed down a little further. If the spindle is on as tight as possible and it still experiences friction, the spindle might be too big. Also check for obstructions that are preventing the spindle to rotate freely. Some models of PlayStations require different size spindles, so you should look up spindles specifically for your model and try those. Never get cheap knockoffs, because they never work right. You might have to sacrifice price to get a genuine spindle for your model, but it will be well worth it.
Lots of things for you to try here, so don't give up. Good luck!
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Jinyuan Lee 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 4
지난 30일: 11
전체 시간: 612
