주요 콘텐츠로 건너뛰기
2017년 9월 22일 출시. Model A1863, A1905. GSM 또는 CDMA / 64 또는 256 GB / 금색, 은색 및 스페이스 그레이.
873 질문 전체 보기
iPhone 8 in infinite bootloop tried everything and EVERYTHING
So after i updated my iphone 8 to ios 12.2, my phone started going on an infinite bootloop i tried everything dfu mode recovery mode no avail. sometimes when it comes off battery I can actually get it to the start screen and even set it up, but when it loses battery/ shuts off its bootloop again. I even removed battery and plugged it in with charger and it still bootlooped. I dont understand the problem AHHHH
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 1개
ALSO when it does get to the start/hello screen the haptic feedback doesnt work
댓글 달기
답변 3개
가장 유용한 답변
Could be just a bad battery. Try getting that replaced and see how that goes.
iPhone will just flash apple logo on and off with battery disconnected so it needs a working battery for the iPhone to turn on.
해당 답변은 도움이 되었습니까?
점수 2
댓글 4개:
really? How come the phone works when I do my little trick thingy until it gets powered on again. During this time the battery works just fine.
all though after the update it was working fine until it randomly shut off
If the phone works fine when the battery is charged but does not when it drops to a certain percentage that points to a bad battery.
The phone works with all percentages battery doesn’t seem to be a problem
댓글 달기
Get New Battery. that’s your problem
해당 답변은 도움이 되었습니까?
점수 0
댓글 6개:
but it works fine when I get it to homescreen zzz
Ah ok. Did you change the screen?
-- test audio also. Can you put the phone on speaker during phone call?
No I can’t put the phone on speaker during a call
If the speaker phone is greyed out during calls and voice memos record shows no recording device found then the phone has an audio IC problem.
To get that fixed the phone will have to be taken to a reputable phone repair shop that does micro-soldering.
this is what is causing the bootloop?
댓글 1개 더보기
댓글 달기
If you haven’t already fixed this, I have found that disconnecting the front proximity sensor altogether works, however, you lose the selfie camera feature…..
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Levy Nguyen 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 4
30일 전: 4
전체 시간: 148
