주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2016년에 제조된 Lenovo IdeaPad Flex 4-1470(모델명: 80SA)은 360도 접을 수 있어 태블릿처럼 사용할 수 있는 14인치 터치 스크린 디스플레이를 탑재했습니다.
After a fall the computer does nothing...
My daughter knocked her laptop off the bed and it hit the floor. I know, I know…
But it happens. Right?
Now when we try to turn it on the power button lights up a few seconds but then goes off. When we attempt to charge, the LED charging light lights up as if charging, but the computer won't come on at all. The screen does nothing. The computer does nothing. Hard reset does nothing….. My husband looked inside and thinks the i/o board is possibly the problem. What would the symptoms be? Do you have any suggestions as to what the problem is and how we can fix this?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
Try re-seating your memory. Also, when you are doing this, remove the memory and turn the laptop on to see if it beeps. If it does, then simply put the memory back in, after removing the power. If it does not beep, then it could very well be your motherboard. Secondly, you might try removing the hard drive( if applicable) and memory. Power the unit up to see if it responds to no memory. If it does, put just the memory back in and see it you get the “Lenovo” logo. If you do, power it down and put the hard drive back in. Try booting it again. If it does not come up with logo then your hard drive is bad and simply needs to be replaced.
Hope this helps.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Stargirl Dot 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 1
지난 30일: 10
전체 시간: 464
