주요 콘텐츠로 건너뛰기
The 2009-2014 Ford F-150 was introduced for the 2009 model year as an update of the Ford full-size truck platform.
Where is my camshaft position sensors on a 3.5 v6 ecoboost
I just can figure out where my camshaft sensors are on this motor
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 3개
선택된 해법
hillmatt26  looks like your engine has 4 variable camshaft timing solenoids ,
이 답변이 도움이 되었나요?
점수 3
댓글 1개:
So how do I know which one is the intake and the exhaust? Is that related to bank 1 or bank 2 positions?
댓글 달기
Hope this helps
이 답변이 도움이 되었나요?
점수 3
댓글 5개:
Are all the camshaft position sensors on this interchangeable? Why are my 2014 ford f-150 lariat ecoboost 3.5l camshaft position sensors is on the top rear of the heads?
This is where they are on the 2011 but all 3.5L ecoboosts year models use the same sensors. I provided the link to the ford parts website to purchase oem sensors and if you scroll down it gives you the list of compatible year models.
Intake part #du102
https://parts.ford.com/shop/en/us/electr...
Exhaust part #du90
After looking at this picture, I see I have two sensors on each side. TWO! Not one, but TWO! OMG. Code p054a refers to the camshaft sensor on Bank 2. Passenger side. Every video I ever watched everyone talks about 1 sensor. Replace 1 sensor. That's it. I need to replace both on the passenger side. I got a mirror to see exactly where it is. All videos refer to getting it off from the top. I actually saw a guy refer to pulling the tire and wheel well off. Wow, I just don't know. I responded to yours since it was posted this year. Thank you so much.
Any input on this from you would be greatly appreciated.
If you have 1 cam, 1 sensor on each side.
If you have two cams, 2 on each side / 2 for each cam
I have a 2013 f150 with the eco boost engine. For some reason all my wires got hot and melted the wires. It looked like the camshaft sensors had three wires going to them. The plugs were melted also. I am having codes p0369-p2307. Just wondering if both had three wires or if one was a two wire. Terry
댓글 달기
Is behind the driver side turbo charger
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
hillmatt26 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 30
지난 7일: 165
지난 30일: 820
전체 시간: 30,012
