주요 콘텐츠로 건너뛰기
Repair guides and support for Panasonic's Viera line of televisions.
417 질문 전체 보기
Panasonic TV Won’t turn on (tx-48ax630b)
Hi
i have an issue where the tv won’t start. It’s 4.5yrs old and the details/ fault are below. Any ideas welcome
Panasonic tx-48ax630b. When turning on the green light flashes 9 times (slightly longer long one on the 9th), then 9 again, then a single slow red flash. Screen try’s to light up but then goes off.
Tried the reset methods but no luck.
.... oh, and the power button has been a bit loose now for a while but still worked and clicks.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
James Algar 9 blinks on your model is for a SOUND_SOS and the most likely culprit is your A-board. The A-board is the main board. remove the back from your TV and check that board for obvious damage. you can always post good pictures of your boards with your question. That way we can see what you see. 기존 질문에 이미지 추가하기
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
귀하의 답변을 추가하세요
James Algar 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 3
전체 시간: 478
