주요 콘텐츠로 건너뛰기
2017년 11월 4일 출시. A1865, A1901. GSM 또는 CDMA / 64 또는 256 GB / 은색 또는 스페이스 그레이. ("iPhone 10"으로 발음합니다.)
1199 질문 전체 보기
Screen not responsive iPhone X
iPhone X screen not responsive but get notifications. did hard reset but no help. no drop, no water, or nothing just issue started. even no update. it happened about few month ago several time but start working its own and one time wont work and apple tech ask me to hard re boot so i did and worked. phone never droped
thank you
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 1개
Even the warranty expires?
댓글 달기
답변 3개
선택된 답변
Apple covers this in their service program, don’t try to repair this yourself.
해당 답변은 도움이 되었습니까?
점수 1
댓글 3개:
Even warranty expired
Yeah this is a special issue, look at their service programs.
Thank you checking now. Can you send a link if you have handy
댓글 달기
가장 유용한 답변
It sounds like a damaged/defective screen to me. The repair costs on the X is quite high so you may want to drop by a repair shop to see if a replacement screen will solve the problem. If it doesn’t then it won’t really cost you anything as opposed to ordering a screen for yourself.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
so i got it fixed. i knew the screen is good but probably conflict within two programs. i did hard restart several time no help. called apple and they said screen is bad and take it to best buy. so i decided to give a last try.
hold down up volume or down volume key WITH HOLDING POWER BUTTON, when it goes to power off, medical id and sos screen just
keep pushing any button until you see a window from bottom pop up, cancel , voice over and one other thing. just leave the device like this and let the battery drained, once the battery drained wait couple of hours and charge it through the computer port. i tried this with the wall charger and did not work.
i think issue was me unlocking with face id and same time attempted to unlock by sliding the bar up to unlock with the pass-code. no patience!!
moral of the story is, human is faster then technology.
good luck
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Mohammad A Butt 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 3
전체 시간: 344
