주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
6s와 유사한 하드웨어 사양의 4-inch iPhone은 2016년 3월에 출시되었습니다. 16/32/64/128 GB 저장 옵션 및 은색, 스페이스 그레이, 금색 또는 로즈 골드로 제공됩니다. 모델 A1662 및 A1723.
iPhone SE multiple issues
Hi,
After going to a store to get my iPhone SE screen replaced my iphone does not boot up (stuck in boot loop) and cannot even hold a charge meaning it will not even power on if not connected to with the power cable.
I have tried:
  • getting a new screen replacement but the problem persists;
  • disconnecting the battery and with the cable connected (does the same)
  • resetting through itunes, it will reset and update but will still be stuck in the boot loop
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 1개
Why didn't you get back to the shop that made the repair to start with ?
댓글 달기
답변 2개
선택된 해법
Hmmm…erratic battery readings…?
Do a thorough visual inspection, preferably with magnification, of the area surrounding the battery connector. There are several tiny SMD components just above the connector. Of particular importance is FL2400, highlighted in red. If it is missing (which can happen when you pry the connector off), then the battery state does not get communicated to the CPU and this can also cause charging issues and fluctuating readings.
This is a common error by DIY fixers and inexperienced techs (or even experienced techs not fully concentrated ;>).
이 답변이 도움이 되었나요?
점수 4
댓글 달기
Install a known good battery. The phone is boot looping because it is not getting any data from the battery.
이 답변이 도움이 되었나요?
점수 2
댓글 3개:
Will try that, thank you
Ok so I replaced the battery and managed to get out of the restart loop. However there still seems to be a problem, I left the phone charging for a few hours and it only charged 15% and it keeps restarting from X to X minutes and everything is boots up it has 1% battery and it changes back to like 8% or whatever after a few seconds. What should I do?
Okay so you know it is not the battery. Since it is displaying random battery percentage it would point to the tigras chip, a partial short on vcc_main or the fpc battery connector. It sounds like a microsoldering outcome in any event.
댓글 달기
답변을 추가하세요
kraki 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 3
지난 7일: 6
지난 30일: 8
전체 시간: 286
