Cause 1
Icemaker Module
The icemaker module is equipped with a motor that cycles the ice ejector arms or turns a tray to eject the cubes into the ice bucket. When the thermostat or sensor on the icemaker tray reaches about 15 degrees Fahrenheit, the motor cycles to release the ice cubes. At the end of the cycle, the icemaker module sends power to the water inlet valve to refill the tray with water. If the icemaker module is defective, the ice maker won’t make or dispense ice. First, depending on your model, make sure that the on/off switch is in the on position or the bail arm is in the down position. If the icemaker module has ejector blades, check to ensure that ice cubes are not stuck in the blades. There are usually test points in the module that a technician can use to further diagnose problems with the module.
Cause 2
Ice Level Control Board
Some refrigerators use an infrared beam to sense the level of ice in the ice bucket. When the ice level reaches the top of the bucket, it interrupts the infrared beam. The control board then shuts off the ice maker. When the ice level drops below the beam, the control board signals the ice maker to make more ice. If the ice level control board fails, the ice maker will stop making ice. Ensure that the ice level control board is getting power. If the ice level control board is getting power, but the ice maker won’t work, replace the ice level control board.
Cause 3
Icemaker Mold Thermostat
The icemaker mold thermostat monitors the temperature of the ice mold (ice tray). Once the mold reaches the proper temperature, the icemaker ejects the ice cubes and refills the ice mold with water. If the mold thermostat is defective, the ice maker will stop making ice. To determine if the thermostat is defective, use a multimeter to test it for continuity. If the mold thermostat does not have continuity, replace it. (Note: If the ice maker is not cold enough, the mold thermostat contacts will open. If the thermostat contacts are open, the ice maker will not make ice. The ice maker temperature must generally be lower than 20 degrees Fahrenheit for the thermostat contacts to close.)
댓글 1개
Did you fix this problem? I replaced icemaker, water valves are working, tube is not iced and temperature is OK. I guessing a board or sensor in the icemaker?
Garym 의 공유
