주요 콘텐츠로 건너뛰기
Xbox One controller was introduced in 2016 with the launch of the Xbox One S and adds Bluetooth support for Windows 10/11. This controller fixes many of the design flaws found on the Model 1537/1697 controllers and is much more reliable. This controller has been replaced with the improved Model 1914 controller.
163 질문 전체 보기
What is easier to replace? The expansion port or the motherboard?
The expansion port on my controller stopped working, haven't opened it up but It is definitely the expansion port (the 3.5mm adapter works just fine in other controllers) I was wondering if the best option for fixing it would be replacing the single port or the whole motherboard.(I have no idea which one its connected to)
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 2개
선택된 답변
I’d open it up and see if you can’t spot the problem, look for burned components:
Xbox One Wireless Controller Model 1708 Bottom Motherboard Replacement
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
The issue with replacing the port is it’s mounted with SMD soldering so you can’t easily replace it. Unless you have a donor secondary board and really good soldering skills, you will mess up the connector if you even try removing it.
That said, it’s rare for the connector to fail in general (unless you spilled Mountain Dew on the port). Try doing what @mayer suggested and look for burned resistors and capacitors. Unlike the connector, it’s practical to replace SMD parts on that level. It also wouldn’t hurt to protect the connector with kapton tape to err on the side of caution.
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
귀하의 답변을 추가하세요
Chris 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 2
전체 시간: 343
