주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Oral-B White Pro 1000은 충전식 전동 칫솔입니다. 이 White Pro 1000은 Type 3756 모델입니다.
Why does motor comes on but brush head does not move
Brush head does not when motor activates
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 2
댓글 2개:
I have this issue as well.
The tear down guide doesn't go into the mechanical portion at the head of the brush.
I have mine open and there is an opening on the back inside that allows me to see some of the gears and they look functional. I can't figure out how to get in further to find the malfunction. Specifically, on mine, the metal 'pin' only vibrates. It is missing the up-and-down motion I recall from before.
I guess I can't add pics to the question as I'm not the op?
@scottbernardis
Post your comment as a new question on ifixit. That way you can add images.
Here's how to do this 기존 질문에 이미지 추가하기. It is the same procedure for a new question.
If selecting the same device as shown on this page for your question then your question will also be linked to the device, (see where it says "6 questions View All" in the device box, top right of this page). If you click on that you can see what others have asked about the device and also what answers there are.
Moderator.
댓글 달기
답변 1개
Most likely one of the gears is stripped that turns the brush shaft. You would need to take the brush apart to get a better idea. Here is a tear-down guide to inside the brush. Open it up and post some pictures of the inside if you need more help.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
douglaschamberlain 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 26
전체 시간: 1,151
