주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Apple AirPods는 2016년 12월에 출시된 무선 헤드폰입니다.
Case not working. Only when charging
My airpods case does not light up when I open the case. But if a put a charger in the light flashes white really fast. And my airpods is on right now and I don't know how to turn they off. Because my case doesn't do anything
Plz help
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 7
댓글 1개
Mine don’t even light up while charging
의 공유
댓글 달기
답변 5개
선택된 해법
There may be a problem with your Airpods case then, and it probably can’t retain any charge, so, it only works when it is plugged in, when the energy is going purely into charging the airpods rather than charging the case.
이 답변이 도움이 되었나요?
점수 3
댓글 2개:
I my case, when it's plugged on charged, it show 100% of charge. I think that if it was a charge retention issue, it would display a critical level of charge instead of showing it fully charged.
One more thing, if I keep the box plugged, I am able to connect the airpods and they are fully charge too. If I remove the box from charge the airpods can't connect.
의 공유
samething with ming
의 공유
댓글 달기
My airpods have a orange light when they are charging but when i try to use them the light turns off and they won’t connect. I recently dropped my AirPods case and it has a scratch on it but I don’t think it’s that. Any tips?
이 답변이 도움이 되었나요?
점수 1
댓글 1개:
I have the same issue too.
의 공유
댓글 달기
You need to replace the case in this situation. I had faced the same problem and as my airpods were not under warranty, i need to pay 1200 indian rupees for the same.
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
yeah they told me the same thing, $179 USD (12603 Indian Rupees) to replace them
의 공유
댓글 달기
In my nothing ear 1 charging case, TWS pogo pins are not working. is it possible to repair? Amy spare parts available? Please let me know
이 답변이 도움이 되었나요?
점수 0
댓글 달기
for me was my connection pins in a case had corrosion after i rubbed votka and use my screw drive i was able to do the fix.
i know it sound bad advice.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Isak_holmgard 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 4
지난 7일: 34
지난 30일: 143
전체 시간: 62,275
