주요 콘텐츠로 건너뛰기
The Lenovo Thinkpad X240, released in 2013, fairly light and compact, and looks familiar to the ThinkPad Line. The X240 is notable for its clunky touch pad.
Why is my Lenovo Thinkpad X240 Screen Black?
I found a decent deal on a Lenovo X240 and found it had no HD and no memory. I found online the specifications for the memory and ordered the “Crucial 8GB (1x8GB) DDR3 RAM 1600MHz PC3L-12800 laptop Memory CT102464BF160B” for and installed a 256GB Samsung SSD drive I had already.
Since I don’t have a power supply with the plug needed, I found Lenovo makes an adapter for the older yellow style barrel plugs and ordered one of those and just received.
I plugged in the laptop with the 135W 20V Lenovo power supply and all I saw is the green LED turn on at the power button and the keyboard backlight flashes once and sounds like the fan is turning. The Fn LED flashes once green and stays green for about 4 seconds and then stays off. The red LED on the top of the screen “I” in Thinkpad stays lit red.
I did the same with the 90W 20V Lenovo power supply though noticed the red LED on the top of the screen “I” in Thinkpad blinked red 3 times when plugging in the power supply and not even powering on or doing anything else.
I just tested without the power supply plugged in and the same effect as with the 135W power supply… only with the external and internal battery.
Prior to plugging in, the power supply… the battery was dead and the laptop did nothing. I’m guessing one of the chargers must have charged one or both of the batteries somewhat.
Finally, I tried to plug in an external known working monitor with no difference when I cycled power.
The screen is black and never does anything in all the scenarios. What are your thoughts?
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 4개
thanks for the this beautiful blog
Your welcome. Thank you.
Probably the scree is bad connected with the motherboard.
@Stefan Gherman Thanks Stefan! I just found the time to look into again and long story short, you are correct my friend. LCD connector wasn't seated fully. Re-seated and taped. Works fine now.
댓글 달기
답변 4개
선택된 해법
The LCD screen backlight is bad for some reason.
Whether LCD assembly, BIOS corrupted to not turn on backlight or a fault on the System Board… I am not sure. If anyone has a schematic for the i7 boards for the X240 or any ideas regarding how to repair without replacing the LCD assembly, please feel free to comment.
Thanks everyone for your support!
Update: Wound up being the LCD connector wasn't seated fully. https://youtu.be/vsoj4ehQFwQ
이 답변이 도움이 되었나요?
점수 0
댓글 8개:
Hi @jafinch78,
Check if there are any fuses on the motherboard around the area where the LCD cable is connected.
Found the following info from this link with regard to a X220 which has a separate backlight cable and an LCD cable and not just the one LCD cable where the backlight power is incorporated into the one cable but perhaps it may be nearly the same. Worth a look ;-)
"There is generally a .5 amp fuse (marked with an "F" on the fuse.). There is also a 2 amp ("N") or 3 amp ("P")."
Hi @jayeff ,
Thanks!
That's more like what I was suspecting. Working with free LED TV's to practice repairing on; I've found the issue is typically bad LED's, then maybe the power supply, then maybe the inverter, then maybe somewhere on the controller board. Logically, thinking about on the Laptop systems and looking more thoroughly into the components level of thinking... the link you noted was the direction I was thinking also since if not a common modular part... the process is designed into the motherboard since instead of being an MCU is a SBC.
Glad this is posted for later reference. I'm going to take a break on this project for a few days or so as I have outdoor work to do. I'll try to make a video regarding also when I find the time to work on. Thanks again!
Hi @jayeff , Thanks for the feedback below as I needed the motivation to do what you note in regards to search for the schematic. I don't recall either if I noted anywhere else and doesn't look like I have on file. Did wind up finding that like you noted quicker than I expected. I'll edit the answer and add the screenshot since is like you note where there is one LCD cable where the backlight is incorporated and not much more than some fuses and caps that I can see from my newbie experience that can fail potentially.
@jafinch78 ,
Great work on finding the schematic.
If all the power supply fuses etc are OK and you have power on the relevant pins at the 30 pin connector it may be worth checking where the LEDPWR lead (pin 28) comes from. (find other ref. point 45 perhaps)
My guess is that wire is used to signal to the display to turn on/off the LED backlights since the power will already be there. Looking at the circuit it's not as though the LED power supplies are being switched on and off on the motherboard, they're directly wired into the connector
Also check the LID_ CLOSE lead (pin 2) as this will tell the LEDPWR lead (via BIOS I assume) to turn off the backlights. The capacitor (or resistor) may be faulty (or something else further in the circuit) so the BIOS might think that the lid is closed and turn off the backlights
Apologies if you have noted this already
Cheers
@jayeff Thank you! I need the affirmations too. very much appreciate your experience and advice. No need to apologize, I really appreciate your feedback as always. Kind Regards!
댓글 3개 더보기
댓글 달기
가장 유용한 답변
Hi @jafinch78 ,
Try disconnecting both the internal and external batteries and see if it starts just on the AC power.
Here’s a link to the service manual for the laptop.
Scroll to the bottom of p.60 to view the necessary pre-requisite steps and then the procedure to remove the internal battery. You should only have to disconnect it, not actually remove it.
The manual also mentions an Emergency reset button hole in the Power system checkout on p.26 which you may have to operate as well to get things started.
Also try removing the coin cell battery p.73 for a while (15-20 minutes - can’t find RTC reset pins) to allow it to get back to default BIOS settings in case they’re corrupted. (Check its’ voltage as well as it may also be flat and if it is as it non rechargeable it will have to be replaced).
If you remove the RAM and the SSD does it behave differently when trying to start?
If you can’t get it going at all, what was its’ working condition described as, when you bought it? Working but missing parts etc or “As is”, because if it’s a faulty systemboard you may have problems...
이 답변이 도움이 되었나요?
점수 2
댓글 23개:
Here is the info on the reset button:
https://forums.lenovo.com/t5/ThinkPad-X-...
The link got me thinking to shine a flashlight into the LCD to see if that is working in case the backlight isn't working for some reason like burnt out, inverter or in the scenario where I made a Repair Guide regarding the A70z Thinkcentre regarding and issue I never saw before: Lenovo ThinkCentre A70z Backlight Cable Replacement
So far removing the batteries has done nothing new, same goes with holding down the emergency reset button for 15 seconds.
I am about to remove the internal battery to get to the CMOS battery and see what that does.
I did however after thinking about the backlight issue above shine a light at the LCD and notice that the "Thinkpad" slash screen is appearing. That's good.
Hopefully, resetting the CMOS will turn the backlight on properly since I doubt the inverter for the backlight is a separate module.
Hi @jafinch78 ,
Not sure but there may also be a lid switch (magnetic - magnet in lid and switch in case or vise versa) which controls the power to the backlight i.e. turns off the backlight power when the lid is closed, which may be faulty.
Either the power is routed through the switch OR the switch sends a signal to the BIOS to enable/disable the power. If the latter usually the switch is somewhere around the Power button. Just a thought.
Both internal and external batteries aren't showing any power which is strange since I was able to power up without the power supply. I do see the 135W power supply for some reason sparked when I just plugged in to the surge protector and now is only reading 8.62V. Wondering if that did something strange since is the PS that came with the laptop... maybe something to do with why that power supply, when plugging in only, made the letter "i" on the cover blink three times?
The other PS is reading 20V though is only 90W. Not sure if related at all or not.
I'll just unplugged the CMOS and will let sit for a while before connecting everything again.
Reading into some more regarding the backlight I found these threads:
Hi @jayeff,
Good call regarding the switch. I'll have to read into that some more. Any references by chance? I guess that makes sense why the external monitor isn't working.
There is a blue and an orange wire ending where the WAN/M.2 SSD card can go (is note used on this system). I guess from the looks of the system, those wires are the WAN antennas. Wow, do those have small RF connectors.
Well, I plugged back in the CMOS battery and now get two beeps... though every other process appears the same as found.
Will check the memory and the SSD when removed next.
Wondering if the "fuse" on the motherboard is bad. I'm not sure the magnetic switch concept is wrong and thinking about hacking that to look like the lid is open as an easier attempt. I guess if that has pinouts that are accessible, see what the state looks like and do the opposite.
댓글 18개 더보기
댓글 달기
I didn’t want to answer this, but there is some potentially dangerous information in the previous answer you best not follow yet until you know if it has an SVP.
Before you do ANYTHING with the system (especially the CMOS battery), get a external display that has VGA if at all possible; it can be DVI/HDMI only, but you will need a mDP adapter like this to get it going as the Thinkpad only has onboard VGA. We’ll get to why I want you to mess with literally anything else before the CMOS battery. It doesn’t need to be a new monitor - something used from a thrift store will work as long as it has the ports you need.
Removing the CMOS battery on a Thinkpad 390E-XX30 is a potentially dangerous mistake; if you can recover the ATMEL chip, you can oops it. However, it is DEADLY on the XX40-present generation with Boot Guard. If you reset the ATMEL chip using the old methods, you will lock the machine out due to tampering and need a motherboard. If you removed it without being sure, this is a deadly error if you had a SVP :(. If I’m reading the previous thread right, pray it never came with a SVP.
이 답변이 도움이 되었나요?
점수 2
댓글 16개:
There is a Analog VGA output on the X240 I have. I am going to set the Display settings to Analog VGA in BIOS and try that next.
99% of thrift store monitors have VGA so it'll work if you have a known good cable and monitor.
I was really hoping I didn't see the part where you tested it and potentially removed it.
Do you happen to know if the inverter for the backlight is in the LCD module/assembly or on the motherboard?
I'm wondering if the inverter is bad or too many LED's burnt out.
I didn't see a backlight setting in BIOS as I read some laptops have I guess.
LED monitors don't use a backlight. They are driven from the motherboard, so if a known good panel doesn't work you need to repair the motherboard.
@nick
I think the monitor LCD's use backlights though around the perimeter of the screen in some designs versus directly behind. I can see the screen display on the X240 when I shine a LED light at certain angles so I know the LCD screen part of the display is working... not the backlight. I'm pretty sure this is correct. Please reference otherwise since would be new to me. I even have a Lenovo A70z LCD monitor repair regarding the backlight with a known issue on iFixit. You can check out my guides for more info.
댓글 11개 더보기
댓글 달기
Hi James.
Just reading your post as I’m having a very similar problem with a T460. I bought mine with a cracked screen and no memory or ssd thinking I could fix it. The cracked lcd changed a slightly lighter shade of black when turned on. I bought a new lcd (which has an inverter attached) but it did the exact same thing. I would only notice that there was life in the lcd when I turned it off. Mine laptop gets power, the fan fires initially and the backlight on the keyboard illuminates but the the power dies after just over a minute.
I’ve replace the lcd, the cable from the lcd to the motherboard. The motherboard. I’m thinking now it might be the power supply as I’ve noticed that the battery isn’t charging even though I have left the power supply plugged in. It could also be the cable from the battery plug port to the motherboard aswell.
I’ve pretty much replaced nearly every component on this machine except for the power related items. It gave me some hope when I saw you posting. Did you narrow it down to definitely being the backlight?
Did you end up finding a solution or did you just let is rest in peace?
Kind Regards,
Niall
이 답변이 도움이 되었나요?
점수 0
댓글 8개:
Hi Niall,
"Did you narrow it down to definitely being the backlight?"
Yes, I think so. The only other more detailed issue would be a corrupted BIOS somehow operating the backlight and maybe I'm thinking the backlight power supply circuit signal path integrity.
Last left off needing to determine like in the answer as @jayeff noted if there is a fuse or component on the board going to the backlight that is bad and needs to be replaced or maybe even the dimmer circuit bypassed as a quick fix if the issue.
I recall prior to that I used a flashlight to see if anything was powering up and displaying on the LCD screen to verify that the LCD itself was working and the issue is the backlight not working. I didn't see where a setting in BIOS turned on or off the backlight, though did see to enable the VGA port. So did that and worked OK with an external monitor.
This was after I got an adapter for the powersupply to adapt the Lenovo X200/E530 round yellow barrel plug style to the X240 rectangular style so I was able to charge the battery and/or run on a power supply.
"Did you end up finding a solution or did you just let is rest in peace?"
Found the solution to use an external monitor for now. Didn't give up on tracing the root cause in the backlight power supply circuit... just was busy with outdoor projects... then other projects I've been studying relating to electronics and RF engineering. Have a new to me $20 UofA surplus store GA-78LMT-USB3 (rev. 4.1) Motherboard - GIGABYTE desktop build and just picked up the $30 AM3+ FX6300 to assess that investment I'm trying to get together to upgrade to a new minimum specs for software and other course work studying.
Lot's of projects and I hope to share here on iFixit shortly.
Thanks for asking... needed the motivation to look back into this repair.
Interesting... my SH72 Mini Electric Soldering Iron just came in the mail too. Excellent timing as a bunch of other electronics sensors projects came in the mail two days ago! Awesome! I'll try to set some time to read into again and tear down to see what I can test and determine with this X240. Also, did you happen to ask a question specifically related to your situation? If not, please create a new question and I'll try to answer there also as I'm sure others will too.
@jafinch78 ,
Might have missed it in your replies, but try searching for the motherboard schematics using the "board number" of the motherboard in the search term.
You may be lucky in that it is out there somewhere. Even if you have to pay a bit for it, it may be worth the cost.
Apologies if you have already thought of this or done this already.
Good luck!
댓글 3개 더보기
댓글 달기
답변을 추가하세요
James Finch 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 2
지난 30일: 34
전체 시간: 8,838
