Whirlpool refrigerator top light and freezer light not working.
Hi, all.
I have Whirlpool WRX988SIBM03.
After about 2 years of use, I had some condensation problem in the freezer so had to fix that by clearing drain hole, after that I notice ceiling light and freezer light not working. only the side lights work when you open the door.
after reading thread about similar problem, I checked freezer light as others said, I notice freeze light doesn’t work when you open freezer. So I replaced freezer light as told but still same thing.
What can cause this? Is this control panel issue in the back?
좋은 질문 입니까?
댓글 40개
Are the lights strobing or flickering?
mayer 의
it was dim before not it's off. no flicker or strobing.
iFIX smartphone 의
I, like the other have got the fridge light syndrome going on.
My unit has one led light in each side.
About a month ago the fridge light would flicker and go dim when I opened the door. I played with the door switch and got it to come back bright, but the next opening it would be dim again. While dim, the freezer light is dark(or very very dim. I can see them)
Now , the fridge side is basically off and dark(if you look straight up at the light you can see they are getting some power but barely) Same for the Freezer side. Wife is PO’d.
BentBow 의
@BentBow
What is the model number of the refrigerator?
jayeff 의
wrs325fdam04
BentBow 의
댓글 35개 더보기
