주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
MSI GE62 6QF Apache Pro는 모델 번호 MS-16J4를 통해 식별할 수 있습니다. 2015년 2월에 출시된 고급형 게이밍 노트북입니다.
Water spill on laptop
I dried the entire laptop parts for more than a week. When i turn on the laptop, screen doesnt turn on,cpu and gpu are not running(no temperature rise at all). Only fans and ssd are running. How do i fix that? Cpu and gpu circuit lines are fried(no idea how circuit works)?
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 1개
Coca cola or other sticky drinks have sugar and other grime which is now on your laptop. Drying it out does not work at all. You can get a replacement motherboard on eBay or bring it to a store. You probably don't have a ultrasonic cleaner and I would advice you to bring it to a store.
댓글 달기
답변 1개
선택된 해법
Hi,
The issue is that you dried out your laptop before getting it cleaned or looked at. Drying it out sped up the process of corrosion on the components that are on your motherboard. When water and copper (motherboard) are mixed with electricity you get corrosion that does not stop and needs to be cleaned in order for the corrosion to stop eating away at the tiny solder points on your Motherboard. Take it to your nearest shop that does SMD soldering and see if they can clean it or fix it.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Dota2forev 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 1
지난 30일: 11
전체 시간: 1,544
