주요 콘텐츠로 건너뛰기
Model A1989, EMC 3358. A refresh of the existing design, with updated processor options and a change to the keyboard materials. Available in Silver and Space Gray. Released in May 2019.
134 질문 전체 보기
Does this have 2 fans like the 2017 model?
Just wondering if this model has 2 fans.
The new entry level machines (1.4ghz) only have one fan.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 2개
가장 유용한 답변
To clarify!
The new low end 2019 13” systems have one fan! Here is the teardown MacBook Pro 13" Two Thunderbolt Ports 2019 분해도
There is two configs! The low end 2 USB-C ports which have one fan and the higher end models which has four USB-C ports and two fans.
해당 답변은 도움이 되었습니까?
점수 4
댓글 6개:
Yes , but I was specifically interested in higher spec models, not the 2 base ones
The four USB-C port models have two fans!
@robin In the case of MBP, models that possess discrete video cards have dual fans.
@v3nuo - The 13" models has intergraded graphics (Iris Plus Graphics 655). The 15" models offer Radeon Pro 555X or Radeon Pro Vega.
@v3nuo the 13" MBP has integrated graphics only. As @danj correctly stated, the 2 port 13" MBP has one fan, the 4 port 13" MBP has two fans.
댓글 1개 더보기
댓글 달기
As always, the 13-inch only has one fan, and 15-inch has two.
https://appleinsider.com/articles/19/07/...
https://www.digitaltrends.com/laptop-rev...
해당 답변은 도움이 되었습니까?
점수 0
댓글 6개:
that is maybe not correct, i have a 2017 13 inch. Touch Bar version, that has 2 fans
Like the 2017 MacBook Pro with Function Keys, the 2019 refresh of the 13-inch MacBook Pro has a single cooling fan.
I know the 2 low spec models have 1 fan, particularly interested in higher spec version
The Fn models had one fan the Touch bar models upto 2018 had two fans. Both the 13" & 15" Touch Bar models offer 4 USB-C. The 13" Fn model only offered 2 USB-C ports. Apple is carrying the two port config over for the low end models
@v3nuo Incorrect. The 2019 13-inch MacBook Pro with 2 Thunderbolt ports has 1 fan. The 2019 13-inch MacBook Pro with 4 Thunderbolt ports has 2 fans.
댓글 1개 더보기
댓글 달기
귀하의 답변을 추가하세요
Robin Bonathan 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 4
전체 시간: 7,061
