주요 콘텐츠로 건너뛰기
6s와 유사한 하드웨어 사양의 4-inch iPhone은 2016년 3월에 출시되었습니다. 16/64GB 저장 옵션 및 은색, 스페이스 그레이, 금색 또는 로즈 골드로 제공됩니다. 모델 A1662 및 A1723.
1049 질문 전체 보기
Is my Audio IC broken?
Hi.
I bought an used iPhone SE from eBay. The Seller only told me that the Screen was Cracked. Today it arrived and I also noticed some other defects on the Phone.
The bottom Microphone doesnt work, and the Headphone Jack doesnt work either.
It only sometimes sounds clear after I put the volume to max, and after a few Seconds it sounds very distorted again. Im pretty sure this isnt a loose connection, because if I turn down the Volume, and then Up, its distorted again.
I already tried to Reboot, Reset, Reinstall iOS, Replug the Ribbon Cable… Nothing works.
What do you think? Should I replace the Part with the Headphone Jack, Lightning Connector and Microphone? Or maybe there is a damage on the Logic Board?
I hope you can help me.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 5개
First thing to try would be to replace the charging flex and possibly the speakers too
But why the speaker? It works, so I dont think I need to replace that.
Torn diaphragm on the speaker can cause distorted sound...
Oops I forgot to mention that the distorted sound comes from the Headphones, not the Speaker. I tried many Headphones, all of them have the same problem, so there must be something wrong with that charging flex or the Logic Board.
Yup so change that charging flex, always rule out easy to replace parts before going to board level hardware as it's more complex and easier to mess up
댓글 달기
답변 1개
선택된 답변
IMHO, I would open a dispute and have the seller accept responsibility for the false ad. Buying used phones on eBay is risky business. You’re better off trying to find something local if possible. It might be a bit more expensive, but you will have better recourse in case of unexpected issues.
해당 답변은 도움이 되었습니까?
점수 2
댓글 1개:
I would second this if the OP purchased a "used" item, eBay offers a good customer protection with those purchases and the iPhone can be returned. However, in my experience, if the item was listed for "spares/repair" one can forget about any help from their side. In such instances one has to rely on personal communication and seller's reputation only..the platform is very "flexible" and forgiving with shady sellers unfortunately.
댓글 달기
귀하의 답변을 추가하세요
Lewin Hoffmann 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 2
전체 시간: 388
