주요 콘텐츠로 건너뛰기
Released on July 28th, 2017, the New Nintendo 2DS XL is a handheld gaming console succeeding the Nintendo 2DS.
203 질문 전체 보기
Why won’t my Nintendo 2DS XL turn on?
Recently, my 2ds xl will not turn on no matter what I do! Just a Week ago it was working perfectly now it won’t turn on? If anyone can give me some advice that pI duo be greatly appreciated :) thank you.(also even if I charge it no lights flash it just won’t turn on
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
@hobi_j check your charger to make sure that it is working. After that check the charging port to make sure that it works and check/replace your battery. That way you have a known well starting point for further troubleshooting. If all of those parts are functioning you will have to disassemble your 2ds xl and check for any obvious damaged components on its motherboard. Post some good pictures of that with your question so that we can see what you see. 기존 질문에 이미지 추가하기 and here is the teardown Nintendo 2DS XL Teardown
iFixit 이미지
안내서
기존 질문에 이미지 추가하기
난이도:
아주 쉬움
2 - 5 minutes
New Nintendo 2DS XL 이미지
안내서
난이도:
운영
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
Uh yeah ok. I am currently not at home where my 2ds xl is but once I arrive I will be able to show some photos of it. Also I will be getting a new cable to see if that works since I have been using the same cable I
Got from my dsi in 2012. (I think I may have lost my 2ds xl charger I don’t know)
댓글 달기
귀하의 답변을 추가하세요
Joel Serrano 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 3
전체 시간: 144
