주요 콘텐츠로 건너뛰기
The Acer Aspire One 751h-1948 is an ultraportable notebook with a screen size of 11.6 inches. It was released on July 1, 2009.
5 질문 전체 보기
How do I fix my acer aspire one 751h computer
My laptop is connected to the charger and when i try to turn it on the light from the on button will turn on and then a noise will happen and it will just stop everything what do i do?
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 3개
선택된 해법
The power jack probably needs to be replaced. Unfortunately this is extremely common. To be sure it's not related to the battery though, try removing the battery, plugging the AC charging cable in and see if it turns on with no battery installed.
이 답변이 도움이 되었나요?
점수 2
댓글 달기
athena sosa depends on this “and then a noise will happen “ which could be a bad fan or a bad hard drive etc. Can you somehow describe that noise. It may be time to open up your computer and take a good look at things like the fan, CPU thermal paste etc. Use these guides Acer Aspire One 751h-1948 to start working on it. Let us know what you find. I’d start with the HDD and go from there.
이 답변이 도움이 되었나요?
점수 2
댓글 달기
Your PC fan is broken and when the CPU heats up it shut down your computer.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
athena sosa 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 5
전체 시간: 125
