주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Kohler는 가정용 및 전문가용 승용 제초기와 정원용 트랙터에 사용되는 가솔린 엔진을 제조합니다.
Mower just clicks won't start
I have a cub cadet lt1050. It's been having problems starting so I replaced the battery and it worked for a while then it started having problems again and I would hammer on the starter to get it going. Now it won’t start no matter what I do. Ive tried jumping the selnoid and it still just clicks. What should I try next?
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 2개
Don't ever bang on the starter believe it or not it's not good for it maybe tapping on the bottom is ok but you can seriously mess up the inside of the starter I went to pick up a starter whose been working on them for 35 years and over heard him telling someone else that
Try turning the engine over by hand it might be the starter is locked into the flywheel
댓글 달기
답변 2개
선택된 해법
Hey Seth.
I’d just make sure the electrical connections between the battery, solenoid and starter are sound, and the battery is fully charged. If the key switch won’t start it, and your jumping the solenoid won’t either, then it’s almost sure the problem is with the starter. Sometimes the gear that engages the flywheel is made of plastic, and it wears over time, requiring replacement of the gear only, instead of the whole starter. Either way, the starter removal and installation is fairly straight forward and simple (don’t forget to remove the ground from the battery before you start).
Good Luck.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
Starter Assist Relay should fix it up. Cheap fix.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Seth Gomez 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 2
지난 7일: 8
지난 30일: 52
전체 시간: 14,726
