주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
iPad Mini 3 Wi-Fi(A1599) 버전용 안내서입니다. 2014년 10월 16일에 발표된 iPad Mini 3는 iPad Mini Retina(현재는 iPad mini 2로 알려짐)의 후속 모델입니다.
Again: Digitizer Replacemtn / Home Button issues
Hi,
i replaced the Digitizer on my ipad mini 3 and am left with theTouchID issues and non-working Home-Button and Touchscreen.
I did not throw away the old Home-Button, but i did cut the Flex cable since i was not aware of the issue when i started changing the digitizer.
Is there any way i can repair the issue? Is there any way to get to the data stored on the ipad? I would not mind to much switching to another tablet, but i need the data on the ipad…
Best regards,
Tobias
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 2개
you do not need the touch iD to work to get the iPad working again
Buy a new digitizer with a home button and fit it
이 답변이 도움이 되었나요?
점수 0
댓글 2개:
The Digitizer i currently have is a new one, because the old one was shattered.
I now got rid off the error i had previously being shown on the start screen (TouchID can not be activated on this iPad), but HomeButton and Touchscreen are still not working
의
Just because it is new does not mean it is working>> You need to test it with one you know works
의
댓글 달기
the connector on the motherboard are probably damaged and needs to be fixed. if you look closely on the golden pins can you se if any are bent or missing? They are quite fragile and removing the screen can easily rip them of
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Tobias Mueller 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 16
전체 시간: 373
