주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Boost 및 Virgin Mobile용 모델 번호 LS676.
Issues with safe mode and power button
My phone completely froze. So I popped the back off, removed the battery, waited and then reassembled it. When it restarted, it was in safe mode (never had it happen before). I swiped the notification bar down and clicked the option to exit safe mode. My phone restarted and I then chose how I wanted to restart it. I chose home & app drawer (what I normally run). My phone loaded up fine and I have access to everything once again. However, now the power button doesn't respond. I mean, I can still turn the phone on and off by double-tapping the screen, but can't take screenshots or use the power button in any way. Please help.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 1개
Hi Stephanie
The problem is definitely with your power button. With the type of failure you’re having I’m guess some type of water damage. Luckily this phone isn’t too hard to work on and the power button is a cheap replacement. I would recommend going for it!
If you find any water damage (white corrosion) inside, you should scrub it gently with some alcohol and a toothbrush to clean it up.
Best of luck!
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Stephanie Bump 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 11
전체 시간: 678
