주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2014년 9월 19일에 출시된 iPhone 6의 수리 정보 및 안내서입니다. 모델 번호: A1549, A1586 및 A1589
Broken LCD or Hardware issue? (Video)
I dropped my phone and NOT ONLY vertical ‘ghost’ lines appeared : I was going to order a new screen + digitizer, however I noticed something else. After a minute of use or so, the screen starts to get eaten away by gray-ish horizontal lines (imgur video). This happens more frequently everytime ( 1.30 minute, then 1 minute, then every 30 seconds.) I could not tell if my iPhone is overheating because I can’t stress it enough (touchpad unresponsive for some areas).
If I had to guess, I would lean towards defective hardware.
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 2개
선택된 해법
I don’t think that is a software issue but you can try this trick to be sure at 99%, record a video using the iOS screen recording, then watch the video on another device, if you still seeing gray lines then it’s a software issue otherwise it’s a hardware one.
이미지
이 답변이 도움이 되었나요?
점수 1
댓글 달기
Tried it, and the lines are not being recorded (brilliant idea btw, haven’t thought of that). Could my problem come from something else than the screen ? Or is there a way to know if this is the screen in particular ?
I already tried to deconnect / reconnect, check connections on the 4 “pins” but nothing changed.
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
iPhone 6 screens are known to be very fragile, the only thing left to see is the motherboard screen connector but statistically, it's very rare so you should change your screen ;)
의
댓글 달기
답변을 추가하세요
domywill 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 8
전체 시간: 123
