주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
컬러 일출 시뮬레이션, 5가지 자연음 및 라디오 기능이 포함된 Philips Wake-Up Light 알람 시계입니다. 2017년 4월에 출시되었습니다. 모델 번호: HF3520/60.
Snooze is not working
Does anyone knows which part is for the snooze? My snooze is no more working.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 2개
가장 유용한 답변
Underneath the white disk there is a microphone (a black round cylinder with a hole in it) that is activated when the alarm goes off.
이미지
The white disk transmits the noise (caused by the tapping on the housing) to the microphone which snoozes the alarm.
So it could be that either the microphone is defective or that is simply blocked by a speck of dust.
I just blew into into it and it worked again.
I do not know how easy it is to replace the microphone, as I have not yet take the lamp apart (it still has warranty)
이 답변이 도움이 되었나요?
점수 1
댓글 2개:
Yes i also found this part and thought about this but i was not really sure about it but i think i will order an Replacment microphone and will play arround with it :)
의 공유
Have you also tried how much the plastic parts need to be vibrating at yours?
의 공유
댓글 달기
Hi I think I found out the problem. There is a Piezo vibration sensor and it's oxidized. Have you seen at which position the sensor is at yours? I think there could be some with the sensor on the right side.
Info the sensor is 20mm diameter.
이미지
이 답변이 도움이 되었나요?
점수 1
댓글 2개:
@timkrzyzanowski did you manage to change your Piezo sensor oxydated ?
I have the HF3520 and my issue come from this sensor as well. Did you find any spare parts ?
의 공유
Hi yes somehow a resolder worked now for 3 years but somehow it was very sensitive. Last month the error occurred another time an this time in soldered an new Piezo 20mm element to the cables. But be carefull to solder with the lowest possible temperature. If you're in Germany I could send you one of those if not you can order them easily at aliexpress or ebay.
의 공유
댓글 달기
답변을 추가하세요
timkrzyzanowski 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 7
지난 30일: 43
전체 시간: 2,641
