주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Samsung의 플래그십 스타일러스 폰이자 2018년 8월에 출시된 Note8의 후속 모델입니다. 6.4인치 디스플레이와 최대 512GB의 내장 스토리지를 갖추고 있습니다.
Wrong file TWRP bootloop
Hi,
After install TWRP from Odin my Note 9 was stay on bootlop 'Samsung Logo' and restarting, i can't go to Download Mode and Recovery but phone only restarting bootloop.
It happend after install wrong twrp files (\twrp-3.3.1-1-star2qltechn.img.tar) i have select on Odin "Rebooting"
What's going now? Regards Thank you for help
Recovery and Download doesn't work, i can't going to him.... only restarting *****
video: https://streamable.com/k242c
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 2개
Hi Eda Ea, did you able to fix the problem , I faced the same one
의
Hi eda ea
i have the same problem
were you able yo fix your phone?
if yes, could you please tell us how?
thank you
의
댓글 달기
답변 3개
가장 유용한 답변
Turn it off full power off take cable out hold volume and Bixby whilst holding plug in USB
이 답변이 도움이 되었나요?
점수 2
댓글 2개:
After a failed attempt to remove the battery and ending up cracking the back glass, what you said was the solution. Just ONLY hold volume up and bixby, then plug in the USB. Thank you very much!
의
i cain't turn off my phone it just go off and on on logo after it's off i plug it in and it starts again. holding buttons doesnt help
의
댓글 달기
Hi Eda ea !
There is always a risk when ROOT a smartphone.
Did you try the recovery mode with the following commands :
Volume Up + Bixby + Power key together for a few moments
이미지
이 답변이 도움이 되었나요?
점수 0
댓글 4개:
I waiting for battery runs out of charge.  And push Volume UP + Bixby + Connect Cable USB, was starting to Samsung logo and bootloop…. i installed TWRP from other model (A6+) my misstake… and have select option in odin Nand Erase and Auto Rebooting…
의
Indeed, if the wrong TWRP model has been installed.
A reset factory will have to be done.
I suggest you consult this link: https://www.hardreset.info/devices/samsu...
의
Not possible it’s same problem….
의
If even this procedure does not work, I am afraid there is no other solution, unfortunately. Maybe another member will have a second solution.
Good luck with that!
의
댓글 달기
please help me i have the same problem
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
eda ea 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 6
지난 30일: 24
전체 시간: 1,506
