주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Xiaomi Mi A2(전 세계적으로 Mi 6X로도 알려짐)는 2018년 7월 다양한 내장 메모리 구성으로 출시되었습니다. 이 기기는 2년간 업데이트를 보장하는 Android One 프로그램의 일부입니다.
Random Locking/Unlocking - Hardware or Software related?
I bought my phone on eBay for cheap since it’s easily repairable and is equipped with “Android One” , the seller had already replaced the display and Volume up/down and power button flex cable inside the phone.
About a week ago the phone started locking and unlocking seemingly at random, doing it almost immediately after I unlocked/locked it by pressing the button myself.
First I shifted towards a hardware issue, corroded contact pads, maybe some water inside the device. Since a factory reset trough the recovery didn’t solve the issue it was clear it has to be the hardware buttons.
The big confusion for me now is:
When I boot it into it’s recovery and control the menu with the volume buttons the power button should press itself like it would with the lock/unlock issue, but it doesn’t!
Is there any known android software issue, maybe an app which is trying to inject a routine in the background that’s doing this?
I don’t want to open my phone, replace everything, close it up and see it starting to happen again because it’s software related.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 2개
If the issue disappears when you boot into recovery mode, then it is most likely a software issue. First try a full system update, and update all the apps. Try resetting all the phone’s settings back to their defaults.
If this doesn’t work, you may have to disable all the apps one by one until the problem goes away in order to find the offending app.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
HI, I got the same issue, did you fix it?
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Florian Koch 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 2
지난 7일: 6
지난 30일: 26
전체 시간: 1,168
