주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
크라이슬러의 Jeep 부서에서 제작한 고급형 중형 SUV인 1세대 Grand Cherokee ZJ를 위한 수리 안내서 및 지원 정보입니다.
Stalling and not starting intermittently
I have a 95 Jeep Grand Cherokee that has less than 100k miles on it. So it’s in great shape for its age. The problem is that it has started to stall when driving it - it stalls when it is decelerating. It only does it every once in awhile. Also, it usually starts right back up but sometimes it will not. If I keep trying it will eventually restart.
My regular mechanic can’t figure out the exact problem so I was wondering if anyone out there has a clue. Thanks!
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 2개
Its a long shot , but I had the same symptoms with a Chev. half ton. After a lot of run around. It turned out to be the gear on the rear of the Camshaft. Pricey to fix , traded up to a ram!!!  Good Luck.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
Sounds like what our 96 GC 5.2l was doing when we had a bad battery. Lots of feathering the gas pedal while braking/stopping. And holding RPMs while stopped & in gear. Try a known good battery.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Annette Givens 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 3
지난 30일: 22
전체 시간: 448
