주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Asus X200CA 노트북은 11.6인치 크기에 무게는 1.2kg입니다. Intel® Core™ i3 3217U 프로세서, Intel® ULV Pentium® 2117U 프로세서 또는 Intel® Celeron® 1007U 프로세서 중 하나를 탑재하며, 2GB 또는 4GB RAM, 320GB~1TB 저장 공간, Windows 8 운영 체제(OS), HD 웹캠을 갖추고 있고 배터리 사용 시간은 약 3시간입니다.
Screen is black, computer runs
I had tried a lot of methods I’ve read, for example the ones where I need to remove the battery and hold the power button for several seconds, even minutes, also the F2 + power button and there’s still no response. I was able to connected to my TV. I read somewhere about going to system manager and deactivate the intel graphics. I did that and then i activated them again and I was able to see both screens. I unplugged the Tv did some work on my computer then turn it off. The next day, I turned the computer back on, and was the screen again black, I repeated the method, and it worked. I just feel unnecessary to repeat this process over and over again, does anyone has an idea what do I need to do
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 1개:
Are you remembering to save your changes if appropriate? Might also want to check your users manual to see if there is a function key toggle for switching between external and internal monitors.
의
댓글 달기
답변 1개
If you can get a display signal to your TV then I’m pretty sure the laptop screen is almost completely dead.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Javier Portillo 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 6
지난 30일: 16
전체 시간: 298
